FAQ on fuel tanks.......diff. specs for years / models, etc...
100917 Views 120 Replies 56 Participants Last post by  abqtao
seems like there are always questions flying around about whether a tank will fit a bike or not.
i think it would be a good idea to do a FAQ on the subject. Anyone want to chime in with input or experience? I will sort it out once there is enough info......
(mods... if there is enough interest, could we pin this for a while to gather input? then I can sort it out and you guys can post it to the FAQ page. [thumbsup])
1 - 20 of 121 Posts
That's a good idea Herm, but I just ask Howie. ;D
I'll sticky it anyway and see who posts up. [thumbsup]
I have a '98 750 and '01 Dark and '02 S4. the cut -out for the seat (indentation) in the tank on the '00 and down is shorter than the "01 and up.
I noticed this when trying to put my '01 corbin seat on my '98.( besides the seat latch being different) as far as the '01 Dark and my '02 S4. the S4 is injected.
hopefully you can add a little tid bit to your list [thumbsup]
MM
Great idea Herm! [thumbsup]
General rule of thumb for all "steel" tanks goes like this.
They're backwards compatible. If you've got an older bike and are trying to fit a newer tank it will fit, but might need a few mods or a change(s). Unfortunately putting older tanks on newer bikes will take more work than most will want to do/bother with for either PITA factor or $$$.
Specific differences are below
from 1993 - 1999 All the carbed tanks fit the same (but the cutouts for the seat are different from the newer 2000+ designs) and they only have 1 fuel line coming out which uses either 5/8" or 8mm fuel line. All steel tanks have 2 drain lines which are 1/4" or 6.35mm sized lines. All carbed models have their fuel filters/pumps outside the tank. You can use a newer tank, but you'll have to also use a newer seat to fit the cut out of the tank (it's only a little off and if you're not a perfectionist, it's livable)
In 2000 & 2001 Ducati made both carbed and FI tanks. The most obvious difference between them is that the fuel filler on top either has just a fuel cap (for carbed models) or a fuel cap which is just inside an aluminum ring (for the FI models).
(FI) All FI tanks have their fuel filters and fuel pumps inside the tanks. And you would remove both the fuel cap and the aluminum ring which the fuel cap mounts to from the tank (gently using the wooden handle of a hammer) to gain access to both the fuel filter and pump. It helps if you've got small arms to fit inside that hole. On the bottom of these tanks there are 4 lines coming out. All 4 of which are bent at 90 degrees. 2 are large for fuel (5/16" or 8mm) and 2 are small (1/4" or 6.35mm). The cut out underneath for the airbox and battery are different than the newer design and will NOT fit newer tanks without a lot of relocating of parts or modifying.
(carbed) These are the rarest tanks as they are for carbed bikes and have the newer seat cutout (which fits everything from 2000 to current in the Monster line), but are have the smaller hole at the top of the tank for only a gas cap and NOT the extra aluminum ring. But it's fairly easy to make any FI tank fit this bike with a little work. Closing off one of the fuel lines and adding the extra aluminum ring (which didn't come with the original carbed tank) and has 8 2mm allen bolts holding it into the tank.
All tanks from this point forward are FI only.
The 2001 S4 tank is special as it has the underside shape of the newer 2002+ style tanks, but it came out in 2001. (FYI- this was the first Monster to use the ST style frame and 5.9 "immobilizer" electronics, all Monsters going forward use this)
From 2002 & 2005/2006 Ducati also went with a different location for the battery and airbox underneath the tank. So the cut out underneath is larger overall (hence why the older tanks don't fit) also the fuel filter is held inside the tank with a C clamp in these tanks, rather than just floating in the previous FI tanks. The easiest way to tell the difference between a 2000/2001 FI tank and a 2002/200x FI tank is by the fuel lines coming out of the bottom. Specifically the 2002/200x tanks have 4 lines coming out of the bottom, but only 2 are bent at 90 degrees (the smaller 1/4" or 6.35mm ones) are bent at 90 degrees and 2 the larger (5/16" or 8mm) ones point straight out of the bottom towards the ground when on the bike.
In 2005/2006 (in the US at least) all the tanks went to plastic. (But there's still a few Metals that were being depleted from stock, hence the 2 year span to actually completely change to plastic) simple check to confim, just check to see if a magnet sticks to it. These tanks have the same cutout underneath for battery and airbox. But have a different fuel filter/pump system that bolts into the bottom of the tank. They only have a gascap on the top of the tank and they use a different mechanism for the hinge.
2007 From what I hear, the S4RS tanks are very differently shaped too. But I've not seen one to tell you what those differences are compared to others.
HTH
  • Like
Reactions: 1
Nice post Terry. I think that the S4 tank was different. Maybe Rameses will chime in. He got a FI tank of the same year and something didn't clear.
Thanks Nate,
I just added the details about the 2001 S4. I was actually thinkin this while I was making dinner (please don't ask) ;)
Good write up Terry. Very well written [clap]. Imagine what you would've wrote up if you weren't cooking!. I knew as soon as I "broke the ice" , that someone else would chime in. Always send in the grunts first [laugh]. So I hate to ask, but you state the hinge mechanism is different. Could you still make it work like maybe on an '02 S4?. I have one eye open for a plastic tank to possibly put on mine. They should've been All plastic from the beginning and maybe I wouldn't have the seeping hinge epidemic and worry about the famous "Ducati Dent"
MM
P.S. your girl, girlfriend's (I.G., Michelle) bike rocks!,,, oh, yours too [cheeky]
MM
You can make it work. You basically need a complete tank including the pump mounting plate, and the hinge bracket, on the frame, from the plastic tank.
Manufacturing is always a cost based endeavor. As soon as it became cheaper to use plastic they did. A lot of people are disappointed with the fuel range even though there are abvantages.
I know my S4 has a smaller tank volume than my 750, but you mean to tell me the plastic ones are even smaller? :-\
yes they are.. The guys with plastic tanks talk of filling at ~120 ish miles. I go 150 all the time on my 900, and have gone 170 without running out.
Thanks for the compliments for both Michelle's and my bikes.
Yeah, it seems as the bikes get newer they hold less fuel... logically it makes sense as the space on the underside of the tanks is bigger (cutting into the gas volume) on the newer tanks and then the plastics I imagine (but have not confirmed) are thicker material as well.
And both Michelle's 2002 and my 2001 will get about 140 when we beat on them, 160 on average and close to 190ish when we're miserly. And these #'s come from riding into the gas station with the engine still running... But I still get nervous if/when that infamous light goes on. Who knows what it's telling me in terms of distance, I just know it's HUNGRY!
I've had to push em and it's no fun!
The skin on the plastic tank is very thick. They are heavy too.
well, looks like all the info is here, and pretty clear cut as well.
at a later date, if it becomes necessary, i will clean this all up and submit it for a FAQ. For now, keep adding input if you got it.
Here are a couple pictures of tanks which fit the S2R1000
1. obvious- the stock tank. note how the hinge sits around the solid piece on the tank
2. older IE tank- uses a different hinge which sits inside the pieces attached to the tank (didnt have it in hand when the pic was taken)
2001cromo said:
In 2005/2006 (in the US at least) all the tanks went to plastic. These tanks have the same cutout underneath for battery and airbox. But have a different fuel filter/pump system that bolts into the bottom of the tank. They only have a gascap on the top of the tank and they use a different mechanism for the hinge.
HTH
Are you sure? I have a 2005 M1000s & I thought the tank was metal. It is dented on the side, and I was about to swap it for a used 2003 M620ie tank I just had repainted.
I should have been more clear. I've updated the above timeline to include " In 2005 (But there's still a few Metals that were being depleted from stock, hence the 2 year span to actually completely change to plastic) simple check to confim, just check if a magnet sticks to it.
that is the same tank i fit on my S2r1k [thumbsup]
should be no problem
HTH
It absolutely is different... check out the parts catalog... testa s4r has oval fuel pump flange. :)
Filed this in another thread, but it is useful here, too:
Ducati Performance CF: SKU code #96922200B
From "FITS ON" link:
Fuel tank
This item fits the following models:
Monster
1000 2005, 2004
1000 Dark 2003
1000S 2005, 2004, 2003
620 2006, 2005, 2004, 2003, 2002
620 Capirex 2004
620 Dark 2006, 2005, 2004, 2003, 2002
620 Dark Single Disc 2004
620 Matrix 2004
620S 2003, 2002
750 2002
750 Dark 2002
750S 2002
800 2004
800 Dark 2003
800S 2003
900 2002
900 Dark 2002
S4 2002, 2001
S4 Fogarty 2002
S4R 2006, 2005, 2004, 2003
S4R S Testastretta 2007
You're right. (About the tank and me chiming in. ;D )
I tried to fit a vertical battery FI tank to my S4 by rearranging the battery. Didn't work.
There's another difference in the tanks. Not all fuel injected tanks are created equal.
It's hard to describe the location, but here goes. On the vertical part of the underside of the tank just in front of the seat/tank merger, the vertical battery tanks have a bulge in them.
On that piece of the tank that comes down to meet up with the frame, the inside part of the tank will hit the left side of the head of the vertical cylinder on a 4v engine whereas it clears a 2v.
Hope this helps even if a bit long winded.
will the gas tank from a 2005 DUCATI MONSTER 650/620 fit a 2003 Monster 800Sie?
1 - 20 of 121 Posts
