I have an 01 Monster S4 with 17K on it. The other day, I went to go start her up and the fans immediatly kicked on (and stayed on) It was 50* outside so it doesn't make sense.
Do I have a stuck sensor/relay/thermostat?? Somebody point me in the right direction...thanks.
It could be a faulty temp sensor of which there are two. Disconnect them one at a time to confirm. Possibly your ECU starting to give trouble. Try disconnecting the battery for a few minutes to reset it. If that doesn't help it may be a short in the wiring to the fans.
