I ordered a damper from Motowheels and even though the description said "all except S4" it wont fit. The frame clamp is supposed to go on the right side of the frame crossbar but there is a gusset on each side and the horn in the center. The airbox is also 2mm from the crossbar so the clamp wont fit anyway.
Anyone else run into this?
Discussion Starter · #2 ·
Thanks ???
Mark,
I have the same problem with an Arrow damper I have been trying to install; so far no solution. You got pix of the clamp? Maybe we can compare notes...
scooby
