· Registered
I have a couple of exhaust leaks on my bike.one on a pipe the other were the exhaust meets the cylinder head.I have tightened them both they are alot better but not perfect.Is this normal.Thanks for any help.
I was told this is normal. You should not hear anything at those points. But when you put your hand near the area connecting the headers to teh cat, you will feel a slight air rush.
it's cuz ducati went to a single-slip design with a gasket. should've stuck with the (slightly more expensive to produce) double-slip fit.
