1 - 20 of 21 Posts
Hit a dip today going 25 and bottomed out.. exhaust came apart. sounds like theres a flapping sound. I blame Leucadia Township.
I'm a dip.... and I'm angered that you hit one of us. >:D
are the pipes bent, or just pulled apart at the flange?
Pulled apart at the flange.. PLEASE tell me i can fix this myself... please...
And.. please.. remove yourself from the road.
unless the pipes are bent.... you should be able to loosen the clamps and mounting bolts.... re-insert the pieces together, and just re-tighten everything.
Doesnt appear that any bending occurred.. however the bottom of the cat pipe is flattened and scraped pretty good. OK. Im gonna do it. wish me luck.
So theres a bushing or gasket or something between the downpipe and the cat pipe that is all mashed up. and.. do you know if i remove the cat bolts, is there a torque setting i should be attempting to reapply?
So the Cat on your S2R is f***ed up?
Sounds like Fate is smackin' you upside the head -- telling you to ditch the cat and get a full Arrow system. >:D [laugh]
Discussion Starter · #9 ·
Yeah i considered that.. then i peeled the sides of my wallet apart from eachother only to find nothin. To be honest.. id rather just have open pipes. Mmmmmmm... that would be sexy. But then i would catipult myself into a very early valve adjustment and my poor wallet would again cough up nothin.
both open pipes and valve adjustments be free laddy!
if you need a cat, I have one. You'd have to pay for shipping from MA.
better thing would be to get a mid pipe.
Discussion Starter · #14 ·
adjust the valves yerself? thats preposterous! down right lunacy.
Do NOT talk me into this.
Discussion Starter · #15 ·
Thanks, i dont need a cat though. If anything i need less cat.
Go ghetto. Use flex pipe and header wrap. ;)
Discussion Starter · #18 ·
i kinda really want to do that! i like that stuff.
you could take it to meineke... ;D
Q
1 - 20 of 21 Posts
