Clif Notes: Broke extended bolts for footpegs...can't find new ones
I have a 2007 monster 695 that came with the Termi high-mount exhaust.
Apparently that exhaust comes with a set of (8) 10mm spacers and extended bolts for the mounting points of the plate that holds the front & rear footpegs. That moves the pegs out 10mm on each side so the exhaust will clear the plates.
On the LH side, the two upper bolts stripped & one of the lower bolts broke off on me when removing them (previous owner overtightened them possibly?)
I've asked a ton of places & they cannot get a set of extended bolts from Termignoni for replacement.
Are there other exhaust companies that use spacers & extended bolts that I might be able to buy a bolt set from?
And if your exhaust uses the extended bolts, can you post up what brand you've got so i can give them a call & see if i can buy a bolt set separately?
I hope that was understandable!
Check out TPO parts...
