Does anyone have any experience or knowledge with upgrading the 4V 916 on the 2002 S4? I have thought about changing the cams to the Superbike ones but is there a site/shop that makes an engine upgrade kit for the 916 (e.g. bored cylinders and pistons)? Thanks for ANY feedback.
Chris
The SBK cams will not be noticeable. SPS cams would, but they are getting hard to find, and expensive when found.
Best upgrade--by far--would be an 996 engine out of an ST4s, and go from there. An interim, quite noticeable and very good "bang for the buck," upgrade would be a Nichols flywheel--which you could swap into the 996 engine when the time comes.
Thanks for the info. I was looking at the 996 upgrade vs. a 955 big bore because the cost is about the same for about the same power. It would come down to the reliability of the 996 vs. the 955; and the 996's would be better. Thanks for the flywheel info; I will check into that as I begin the 996 build.
