So I just a 07 Ducati monster 695 it rides really good but for the first time the engine light came on. Even after it was on it was still riding good. The light did come on after the gas light came on, not sure if that’s why? Also it did come on after I hit multiple red lights so the bike was warming up a bit. So don’t know if it was any of those or something else. Would like to know if it has happened to someone before. Thanks in advance
My first guess would be the tmap sensor, second would be lambda related. The OBD system is pretty minimal. I'd get the necessary cable and software to check the code(s) and clear them. GuzziDiag is your best bet. See if it comes back before you start replacing things.
Thanks I’ll look into the cables to check the codes
