61 - 76 of 76 Posts
Anybody know what this code is? Google doesn't come up with very many results, it's possibly exhaust servo. I have the servo cable disconnected at the exhaust, but it's still plugged in.
Melcodiag also doesn't clear it.
Bike is a 2017 Monster 1200S with Slip-on and Rapid Bike Evo tuner.
Discussion Starter · #62 · (Edited)
P1007 Exhaust valve [Calibration - Mechanical stop with valve closed exceed: cable over travel]
Servo motor cable sometimes needs tension. Re-connect the cable and see if it disappears.
You may require a servo eliminator gizmo if it also triggers a CE light on your display while the cable is disconnected.
Alternatively, some of the Multistrada guys have added a spring at the end of the disconnected cable to trick the servo detection.
Thanks DarR. I just hooked it back up, hopefully it goes away on my next ride.
Weird, it's been unhooked for 6+ months without any errors. Took a while for the code to pop up.
Hey guys, newbie from New Zealand, have a 2015 monster 821 with 4,500km on the clock and the oil service light has come on, it was serviced at 1,000km so i want this light off. Have seen these diagnostic tools on amazon that claim they will do what this thread is discussing, my question is two-fold does anyone know what the ECU is on a 2015+ monster 821 and has anyone had luck in trying these? I dont think these do the Melcodiag which many discussions seem to be referring to. Thanks for your help in advance, Ducati's require more fussing over then Triumphs :)
[ame]https://www.amazon.com/moto-solutions-Diagnostic-Service-Ducati-GILERA/dp/B07S85FNV4/ref=sr_1_2?keywords=ducati+DIAGNOSTIC+KIT&qid=1576706783&sr=8-2[/ame]
Discussion Starter · #65 · (Edited)
... my question is two-fold does anyone know what the ECU is on a 2015+ monster 821 and has anyone had luck in trying these?
Your ECU is a Conti Synerject Easy-U1. I have not yet been successful in clearing the oil lamp warning with JPDiag's Melcodiag.
I'll let others chime in for the second part of your question but it's using the same software.
Thanks for posting that link. Very interesting.
Yesterday, having just added fuel stabilizer to winterize my M1200R I started the engine to let the stuff go through the whole system.
Took a few attempts to keep it running as the Monster 1200's are cold blooded beasts. On one of those attempts, I got a error message and the engine light came on...Rats.
Oh, well, I'll have it reset in the spring.
BTW, -2c is way below the Ice Light warning which comes on around 4c.
Today, I decided to fool around with the DDA / ELM / USB cables I had purchased from www.lonelec.co.uk for the Panigale which I have never used.
Using the software that came with them I was able to reset the light....:grin
Who-da-known!
Diagnostic Interface for MelcoDiag TuneECU DDA
will it work on a 2018 monster 1200 to reset service light
Who-da-known!
will it work for a 2018 monster 1200
A Question for the group need some advice.. I Instilled the buy pas valve my exhaust Termin2018 Multi Strada . After 2 weeks of riding the Red Oil light came on ,no leaks and no over heating problem. I belive it’s a soft ware issue any thoughts..G
Hi everyone, I recently purchased the kit from Lonelec but initially had trouble connecting to the bike with my laptop - it would connect for a few seconds and then disconnect again. This was with both Melcodiag and JPdiag software. Turns out that if you have the pig tail harness installed (not the DDA connector under the seat) for trickle charging the battery with a tender, you should unplug this from your tender before trying to connect. Once I did this, I connected with no problems several times. I asked Lonelec to add this to their instructions.. Hope this helps anyone who may be having issues. Cheers!
You actually need two cables:
One to connect to the bike's Ducati DDA plug under the seat. (the 4 pin is found on the newer Ducati bikes otherwise it's a 3 pin)
Ducati 4 pin DDA to 16 pin OBD2 Adaptor Cable Lead
and one to connect this cable to the USB port on your computer.
ELM327 Interface
I bought both as a kit:
I purchased the kit, downloaded the software, and I have licence and I have drop the licence into the file that contains the melcodiag. The program connects to the ecu fine. However when I try to clear a code, a prompt comes up saying my bike is not supported. My bike is a 2015 Monster 1200s.
Any idea what's going on here?
I recently had a check engine light on my 2014 Monster 1200 as well. Ended up purchasing this adapter from Amazon and got it super quick. It should work with any 4 pin diag connector and it is prime so free shipping.
Discussion Starter · #76 ·
Hi Matt, Sorry, I can't explain that. I can clear a code on my 2016 Monster 1200R.
All I can suggest is to run it by JPDiag.
  • Like
Reactions: Matt Dennis
61 - 76 of 76 Posts
