Having only ever riden one bike ....... my monster 696. i am interested in knowing how other bikes (in general) behave when chopping the gas in second (sometimes third) gear ......... the monsters engine braking is severe immediately (which i an used to) ........ was wondering how other bikes compare ??. Its obvious down to the gearing right ???
I was used to riding metric four cylinder bikes before I got my Ducati. It took me a while to get used to the twin. The fours seemed to spin easier and not be as touchy on/off the gas. I think the Ducati forced me as a rider to learn how to be smooth on the throttle.
Super Moderator
In general, an engine with more cylinders (and the same overall displacement) will rev more quickly, and engine brake less. So (all else being equal) a 700cc twin will have more midrange torque, rev more slowly, and engine brake more than a 700cc four; and a 700cc single (thumper) will have all of those characteristics more strongly than the twin.
Note that it is not ideal to engine brake a lot; that stresses the clutch a bit. Use the brakes to slow down; that's what they're for, and brakepads are cheaper than clutchplates.
PhilB
Definitely, riding a large-displacement, high-compression twin will help you learn to be smooth with your throttle inputs.
"the monsters engine breaking..." LOL.
Engine braking...okay.
Engine breaking...we don't like that so much.
Twins definitely engine brake harder than other bikes. My S2R probably slows down about the same as my SV650 did. My VFR did it quite a bit less despite it also being a V engine. The first time I rode the VFR, I came onto a highway offramp way too hot as I was so used to the SV that letting off the throttle on the VFR seemed to hardly cause it to decelerate.
