I'm about ready to buy a lightened flywheel but I'm concerend about the longterm effect an unbalanced crankshaft will have on my engine. I ride my bike alot and I don't want to have to freshen up the engine before due time or cause premature damage. Has anyone put on alot of miles with a light flywheel, over 30,000 or so.
Thanks,
murry
The flywheel on a Ducati is a flywheel not a counterbalance. There is no effect of running a lighter flywheel. I don't mean to be picky but have you ever looked at a Ducati flywheel? They are just a weight hung on the crank they are not used to balance anything in the engine. And when balancing a Ducati engine the flywheel isn't even used. If your engine was balanced before you changed the flywheel it will be in balance after you change the flywheel.
Thanks for the replys, and no I haven't looked at a ducati flywheel. I didn't know that the cranks were not balanced with the flywheels bolted to them, but I do now. I just pictured a small weight attached to the flywheel to balance it.
murry
