Hi gang
I installed my alu LP marker lights this weekend ( Tx chris ca cycleworks) and all was working well before I installed the front headlight.
Had a similar problem. Something is grounding out. You might check to make sure the mounting hardware isn't touching something it shouldn't. Also, sometimes the bulbs themselves can be out of place just enought to rub the sides of their housing leading to a ground. Hope that helps.
