hhmmm....Does fuel pump relay continuosly click when key is tuned on? if it does.. the shop replaced my wiring harness under waranty and it worked fine after the...others have had to have the ECU replaced....if it is an 02 take it to the shop use the warranty!
Well, I had to give up and take it to the shop. I was able to push start the bike, I could jump the stater. I found that one of the relays under the gas tank was not getting power. So it has to be between that and the stater switch or it could just need a computer reboot. I don't know.
Dude, I think the best thing to remember here is that the warranty is your friend. I don't care if you just need a fuse, that is a freebie not to be overlooked. Use it for as much as you can and save the head scratching for much later down the road when it's on your dime. Now here's hoping you have nothing but trouble free miles from here on out!
