Hi everybody...
Just got myself an Monster 750, and found some strange electrical (on ducati!? no way.. ;o) problems.. I would be greatful for any help...
1. Neutral light doesn't always start (but sometimes!), even thou gear in neutral
2. Engine doesn't stop when I put down the stand (I checked the swith at the stand and it works) how should this work!?
Thanx...
//Carl
Discussion Starter · #2 ·
1. ? open circuit in loose wiring connection.
2. Maybe it has a kickstand bypass installed?
Original method was kickstand down, no start, and engine kill if lowering stand to prevent taking off with kickstand down. If it has the bypass from Evoluzione, I believe it would kill the engine with the stand down once out of neutral.
I could be wrong about that though, or someone may have run their own bypass.....
