·My headlight is out....It has been flickering for several months when I turned the bars to lock the steering. About two weeks ago it started to flicker more and now it is out.
Narowed it down to a bad grounding wire. All the other lights work and the fuse is good. This is on a '00 900 almost like the wire fatigued and finally broke. I dont really want to tear apart the wiring harness to find this sucker. Were does the head light ground to the frame or the rest of the harness. I have narrowed it down to the main harness all the plugs behind the headlight are good. Any ideas????
