I bought my '08 S4Rs with a full Arrow 50MM race system, no O2 sensor, Termi carbon cans, air box chop/and K&N style air filter...and I assume the DP ECU.
Here are the numbers off the ECU stickers:
left (outboard) side - 96517906B
right (inboard) side - 2235SE01 (this one is plastered over another sticker covering other numbers, but the bar-code is still visible)
What ECU is this?:confused:
Relatedly, if I want to change to another exhaust (long story for later), I'm thinking under-bike QD Ex-Box, can I retain this ECU and have it tweaked to the new system, or will I need to add a PCIII?
If you have Termis's and open airbox, then you have also DP ECU. If you like to change termi's propably you need to do notthing. You'll notice surely if the bike don't run like before changings and then you just let to tune your DP ECU. DP ECU is tuneable.
