I have an S2R with the factory brake setup. The question I have is there an easy way to remove the inner part of the disc from the outer part? If so, can you use the fasteners to reassemble the disc?
I am kicking around the idea of painting the inner part black.
Thanks guys,
Swanny
Getting the stock buttons out will invlove a drill, some swearing and persistence.. but it's not really hard. But you do ruin them in the process. No biggy since better, full floating buttons can be obtained easily. Those ones will also be easier to replace/remove in the future.
