1 - 11 of 11 Posts
Niiiice, I'm looking to change my tank. But I don't want the stock look. Would you be interested to make one for me? I can send u a couple of designs, but I'm not sure how u can get the sizes right.
I asked the same question on the other board..
"$2100".
"since the monster's tank is not very complicated I think we can produce at a cost of 2100 for the single piece, if there were several people interested, a little less could be done"
Rob.
Discussion Starter #9
Very nice. Has to be expensive.
I'm curious how you make them. The process. Not that I want to do it myself.
to make a tank we start from a sheet of aluminum sp 1,5mm then the various sections of the tank should be cut, we begin to beat all the parts, we only weld together the upper part and you can check it all out lower part and weld it all together
How do you map out the tank to know the sections to cut?
Do you have a sacrificial tank to cut up?
Discussion Starter #11
the tank is cut on the corners at the top, after this it is welded in and out but the weld out is eliminated.
I did not sacrifice a tank, to make this I built some references.
1 - 11 of 11 Posts
