Ducabike Clear Clutch Cover Engine Case[/URL]
Was: $799.99
Sale: $619.00 * FREE Shipping
Ducabike Ducati wet clutch case cover with clear clutch cover. This is a very unique item that is only manufactured by Ducabike. CNC machined from a single block of aluminum then anodized. Choose between a silver or black case cover and then your choice of clutch cover ring color. The leading edge of the outer cover will protect the Plexiglas cover from breaking in the event of a fall. This kit includes all the hardware needed and no modifications are required to install.
This kit does not include the wet clutch pressure plate ring #CCDV01SM seen inside the clutch. It is available separately as it does not fit all models that the clutch case does.
Fits: SS 750ie-800ie, M620ie-800ie, M695, M695, M796, M1100, M1200, S2R800, ST3-ST4S, MTS620-1100-1200, Sport1000/S, GT1000, 848, Diavel, Scrambler...
NOTE:
For the Multistrada 1200 you will also need to purchase #CCDV01R, which is a support bracket for the lower cowling.
If you are installing this on these models: Monster 821, Hyperstrada 821, Hypermotard 821 or a Scrambler, you will also need to purchase a "Ducabike Mechanical Clutch Actuator".
Optional:
[/URL]
Ducabike Ducati Wet Clutch Pressure Plate Ring[/URL]
Was: $49.99
Optional wet clutch pressure plate ring CNC machined from aluminum and anodized in your choice of color when using the Ducabike we clutch case cover #CCDV01D or #CCV01E
* FREE continental USA shipping on orders over $100.
* Outside continental USA, use shipping passwords:
GLOBAL250 gets 25% off shipping on orders over $250
GLOBAL500 gets 50% off shipping on orders over $500
GLOBAL750 gets 75% off shipping on orders over $750
* Register on the Motowheels website for Free forum or upgrade to lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
