1 - 8 of 8 Posts
Anyone have recommendations on the best dual headlight kits? I am looking for ones that will take the PIAA headlights, and hopefully will be as aesthetically pleasing as the Monster itself!!!
I heard that Abhi, a fellow DML'er, sold Duc-Duals not too long ago and they are now up and running... [clap]
I believe the name of the company is Il Duce Moto ([email protected]) and they continue to offer the halo style dual headlight kit... The kits uses a standard H3 55W bulbs and can be changed out very easily...
I have a set on my girlfriends bike and we both love it... They give off a TON of light and are a piece of cake to install... Good luck and ride safe!!!
The 2v alternator is barely able to keep up with two H4 bulbs.
Install a HID kit and enjoy better light than 2 H4's.
2volt or 2amp? Either way it doesn't sound right. A single 35 watt bulb draws 3 amps on it's own. Then you need to power the rest of the lighting, gages and ignition.
2-valve
Hey Dakinebusa!!! As you mentioned, it's my understanding as well that the HID conversion draws a lot less amperage and gives off a TON more light...
I'm hoping to do a mod that will incorporate the HID on one side of the Duc-Dual set up... It should be a piece of cake however I'll have to find a good place to locate the transformer... I've found a few kits that actually offer a longer electrical wire which allows for more options...
Ride safe!!!
HOLY THREAD-FROM-2003 BATMAN!!!
1 - 8 of 8 Posts
