1 - 20 of 20 Posts
Does anyone know of a source for water-proof caps for the oval O2 sensor in-line connectors?
Or a source for the plugs that I can seal with silicone and use as caps?
DUCMONROB said:
Why are you taking out the sensor?
In-line connectors, not sensor. Sensor is disconnected, I want a clean and positive water-proof seal.
Molex connection?
There's a post about picking up connections here I think
http://www.partsexpress.com/
Hey Ducmonrob I saw your earlier post regarding Pat Clark. I'm a Vegas rider myself, even bought my bike there. Drop me a line if you wanna ride sometime.
I stand corrected... Found the link of the post I was looking for. See Slash's respose about the Amp Superseal 1.5 4 pin connector
http://www.ducatimonster.org/smf/index.php?topic=56438.0
FYIW I took Larakat's advice and just gooped up the connection with dielectric grease before taping up. Haven't had any problems with water since but if you got the right caps you'd prolly be better off in the end.
Good luck.
Hey gnostic! I was visiting Vegas all the way from Australia! [thumbsup]
Top place. Pat Clarks mechanic was a realy nice person too! [thumbsup]
Don`t worry I`ll be back some time soon.
Rob
Cool definitely let me know if youre back this way, I'll show you some of the most beautiful desert around.
If you're talking about Mike Lancaster the guy is the best wrench around for miles. Nice as hell too.
Just curious,
Why not cut the O2 sensor harness off of the plug and then lock it back into place? It should be waterproof, and you're probably not planning on putting the sensor back on, right?
Ken
Yea Mike thats him. Top bloke. I wish I had a mechanic in my area like him! [thumbsup]
Rob
KenSwift said:
Just curious,
Ken
I could be wrong here but the PCIII that is being developed is going to be designed to use the o2 sensor. If not then we could technically use a PCIII from a non-o2 sensor equipped DS1000 motor (411 model I think)..
<hides>
<hides>
If the PCIII ends up using the o2 sensor, that will be great (my Arrow has a bung for the sensor and I haven't yet cut it myself).
I'll keep my fingers crossed for it to come out soon.
Ken
Discussion Starter · #12 ·
I'm running the 1717-411 listed for the '03-'04 Ducati 1000.
Seem's to work just fine.
What map are you using and what mods to bike?
Thanks,
Ken
Discussion Starter · #15 ·
Thanks,
Ken
Ken,
The bike has a K&N filter with stock air box lid, Spark header, and an Akrapovic slip-on. Map is custom by Big Valley Motorsports in Reno, NV.
Hey Sieg can you PM me an email address I can contact you at? I'd like to talk to you about this if you dont mind.
This is great! [thumbsup]
Are you running with the oxygen sensor?
I`d like to know more!
Rob
1 - 20 of 20 Posts
