· Premium Member
I need to replace the push-rod (simple enough) and the pin-bearing that (when everything is assembled) sit around the pushrod between the seals.
If I did an adequate job explaining this, can anyone help me figure out how to remove and replace the pin-bearing?
Thanks,
Tigre / Steve Metz
'00 M944s
· Premium Member
This topic just came up recently, and Chris Kelly posted some good info. Do a search for needle bearings and/or clutch push rod. Set the max age parameter to at least 90 days for the search engine and you should locate the thread. Getting the old bearing's remains out sounds tedious, but doable.
