·I have a couple of questions about the DP full exhaust system. I have a 96 m900 and just took off my sil motor 2-1. The DP is a high mount 2-2 45mm to 50mm. Where the pipe goes into the exhaust maifold the tolerance is way off. The sil motor system had a sleeve which measures 48.2mm and the DP has a range of 47.2-47.5 (out of round). Should the fit be this off, or is the sealant suppose to take care of this? Also does anyone have a pic of one installed, the cans seem to be down quite low for a high system. Any info would be great, thanks
