1 - 15 of 15 Posts
I am about to change my oil again on Saturday and was wondering if a torgue wrench should be used for the drain plug. I personally don't use one (very very expensive tool) and just tighten the plug on hand (even the Duc dealer does that) looking out not to overtighten it. I've read some topics in here and somewhere else who strongly suggest the use of a torque wrench even in the oil change.
Am i do it all wrong? And if i am, what is the correct torgue for a monster 620 ?
I've never used a torque wrench on mine. I aim for fingertight plus a little bit, and wait to see if it's weeping any oil the next morning and nip it up 1/16th of a turn if needed. I think the biggest danger is stripping the thread in the case (which turns into an expensive split-the-cases repair job if you screw it up).
big
My S4 service manual has the torque at 30 ft-lb, which is pretty tight.
i'm also in the "just get 'er good and snug, and see if it weeps oil later" crowd.
that's also how i tighten my filter, and i'm pretty sure there's an actual torque spec for that, too.
When your oil drain plug backs out 120 miles from the nearest Ducati mechanic you'll wish you'd bought that torque wrench. It's cheap insurance IMHO.
No...after snugging up with the ratchet, I give the ratchet handle a little love tap with a hammer. Same tap to get it off for next change...never any leaks.
I do use a torque wrench on the plug. It doesn't take much effort to reach the 30lbs-ft, and I'm more afraid of over-tightening than under if I do it by feel.
On the filter I hand-tighten like my old shop teacher told me. (Interesting side note: the previous owner was a duc-mechanic at a dealership & when I got the bike it was leaking at the filter. He hadn't tightened it enough.)
--Jeff
I am of the school "technician tight" when it comes to oil plugs. ie wrench it up and give it a little bit extra by "feel"
BTW- anyone know exactly how engineers establish a torque figure for a fitting such as an oil plug?
Shooter said:
-----------snip----------------
For threaded fasteners in general:
It's possible to calculate the clamping load for a particular torque, although it's *very* dependent on the plating/material of the male and female threads, as well as the lubricant (if any) on the threads and the mating area of the head.
The necessary clamping load is usually defined by whatever the fastener is holding in place, whether that's a rod cap or a cylinder head or a sidecover or whatever.
Stronger bolts can provide more clamping load, up to the limit of what the material under the bolt head can stand.
For something like an oil plug, it's probably less scientific.
Like: 'We've torqued that plug to XX ft-lb on our durability test bikes for the last ten years, and none of 'em ever fell out, and the mechanics never stripped any either.'
Nope [thumbsup]
Never used to use a torque wrench on my Kawi. Then the oil plug vibrated out and ended w/ me sliding across the pavement on my visor. I torque it down now.
1 - 15 of 15 Posts
