1 - 14 of 14 Posts
Ok, the K&N site lists 2 filters for the m750: DU-0900 and DU-9098
Now I don't usually second guess application guides, but I noticed something strange for the m750: They used one filter until 1997, went to a new filter model for 97-98, then went back to the original filter for 1999+.
The DU-0900, according to their site is used for:
http://www.knfilterchargers.com/search/applications.aspx?Prod=DU-0900
K&N Applications for DU-0900
2002 DUCATI 900SS I.E. 900 - All
2001 DUCATI M600 MONSTER 600 - All
2001 DUCATI MONSTER M900 CROMO 900 - All
2000 DUCATI M600 MONSTER 600 - All
2000 DUCATI MONSTER M900 CROMO 900 - All
1999 DUCATI 600SS 600 - All
1999 DUCATI M600 MONSTER 600 - All
1998 DUCATI 600SS 600 - All
1998 DUCATI 750SS 750 - All
1998 DUCATI 900SS 900 - All
1998 DUCATI 900SS FE 900 - All
1998 DUCATI M600 MONSTER 600 - All
1998 DUCATI M750 MONSTER 750 - All
1998 DUCATI MONSTER 900 900 - All
1997 DUCATI 600SS 600 - All
1997 DUCATI 750SS 750 - All
1997 DUCATI 900 SUPERLIGHT 900 - All
1997 DUCATI 900SS 900 - All
1997 DUCATI M600 MONSTER 600 - All
1997 DUCATI M750 MONSTER 750 - All
1997 DUCATI MONSTER 900 900 - All
1996 DUCATI 600SS 600 - All
1996 DUCATI 750SS 750 - All
1996 DUCATI 900 SUPERLIGHT 900 - All
1996 DUCATI 900SS 900 - All
1996 DUCATI M600 MONSTER 600 - All
1996 DUCATI MONSTER 900 900 - All
1995 DUCATI 600SS 600 - All
1995 DUCATI 750SS 750 - All
1995 DUCATI 900 SUPERLIGHT 900 - All
1995 DUCATI 900SS 900 - All
1995 DUCATI M600 MONSTER 600 - All
1995 DUCATI MONSTER 900 900 - All
1994 DUCATI 600SS 600 - All
1994 DUCATI 750SS 750 - All
1994 DUCATI 900 SUPERLIGHT 900 - All
1994 DUCATI 900SS 900 - All
1994 DUCATI M600 MONSTER 600 - All
1994 DUCATI MONSTER 900 900 - All
1993 DUCATI 600SS 600 - All
1993 DUCATI 750SS 750 - All
1993 DUCATI 900 SUPERLIGHT 900 - All
1993 DUCATI 900SS 900 - All
1993 DUCATI M600 MONSTER 600 - All
1993 DUCATI MONSTER 900 900 - All
1992 DUCATI 600SS 600 - All
1992 DUCATI 750SS 750 - All
1992 DUCATI 900 SUPERLIGHT 900 - All
1992 DUCATI 900SS 900 - All
1991 DUCATI 600SS 600 - All
1991 DUCATI 750SS 750 - All
1991 DUCATI 900 SUPERLIGHT 900 - All
1991 DUCATI 900SS 900 - All
1988 DUCATI 750 PASO 750 - All
1987 DUCATI 750 PASO 750 - All
Then the DU-9098:
http://www.knfilterchargers.com/search/applications.aspx?Prod=DU-9098
K&N Applications for DU-9098
2004 DUCATI 1000SS 1000 - All
2004 DUCATI 800SS 800 - All
2004 DUCATI ST3 992 - All
2004 DUCATI ST4S 996 - inc. ABS
2003 DUCATI 1000SS 1000 - All
2003 DUCATI 620 SPORT 620 - All
2003 DUCATI 800 SPORT 800 - All
2003 DUCATI 800SS 800 - All
2003 DUCATI ST2 944 - All
2003 DUCATI ST4 916 - All
2003 DUCATI ST4S 996 - All
2002 DUCATI 750SS 750 - All
2002 DUCATI MONSTER 900 DARK I.E. 900 - All
2002 DUCATI MONSTER 900 I.E. 900 - All
2002 DUCATI ST2 944 - All
2002 DUCATI ST4 916 - All
2002 DUCATI ST4S 996 - All
2001 DUCATI 750 I.E. 750 - All
2001 DUCATI 900SS I.E. 900 - All
2001 DUCATI M750 MONSTER 750 - All
2001 DUCATI MONSTER 900 I.E. 900 - All
2001 DUCATI ST2 944 - All
2001 DUCATI ST4 916 - All
2001 DUCATI ST4S 996 - All
2000 DUCATI 750 I.E. 750 - All
2000 DUCATI 900SS I.E. 900 - All
2000 DUCATI M750 MONSTER 750 - All
2000 DUCATI MONSTER 750 DARK 750 - All
2000 DUCATI MONSTER 900 900 - All
2000 DUCATI MONSTER 900 I.E. 900 - All
2000 DUCATI MONSTER M900 DARK 900 - All
2000 DUCATI MONSTER M900 S 900 - All
2000 DUCATI ST2 944 - All
2000 DUCATI ST4 916 - All
1999 DUCATI 750SS 750 - All
1999 DUCATI 900SS 900 - All
1999 DUCATI M750 MONSTER 750 - All
1999 DUCATI MONSTER 750 DARK 750 - All
1999 DUCATI MONSTER 900 900 - All
1999 DUCATI MONSTER M900 CITY 900 - All
1999 DUCATI MONSTER M900 CROMO 900 - All
1999 DUCATI MONSTER M900 S 900 - All
1999 DUCATI ST2 944 - All
1999 DUCATI ST4 916 - All
1998 DUCATI ST2 944 - All
1997 DUCATI ST2 944 - All
1996 DUCATI M750 MONSTER 750 - All
At first glance everything looks good, 9098 for the newer ducs, 0900 fir the older. But look at the 9098 listed for a 1996 monster 750, 0900 for 1997-1998 monster 750, then back to 9098 for the 1999+ m750.
Did ducati really go from one filter, change for 2 years, then go back??
Discussion Starter #2
Re: DIfference between K&N DU-0900 and DU-9098
Oh and where's the cheeeeepest place to get a K&N?
S
Re: DIfference between K&N Filter DU-0900 and
just to confuse you a bit more,
i ran a du-9001 on my s4 before switching to pod filters. bought it from http://ducatigarage.netfirms.com but they unfortunately no longer carry k&n's for ducati's.
Discussion Starter #4
since we are talking K&N's -- what is your take on the twin pods versus the modded airbox with a panel filter replacement?
S
my s4 ran really well with the open lid + panel filter. the only reason i'm running pods is because i sent my stock box to a carbon fiber parts manufacturor with hopes of getting a carbon one made. the stock box had to be destroyed to create a mold for the CF counterpart. this was a risk i was aware of and unfortunately, a CF counterpart was never successfully made.
so i went with pods. the work very well but i haven't had them on for very many miles. if you dig the look and want to shed some weight, go for it. but i think the stock box does a very good job (with the lid cut) of airflow and air control for the intake.
for what it's worth, when i stuff the 998 motor in, i'll be switching back to an airbox setup. partially because i think it will work better (will be going with a "ram air" setup as on the SBK's) and partially cuz i don't think i could apply pods to the "shower" type injector setup that the 998 uses.
i think most people will tell you that it probably doesn't help performance all that much compared to the modded airbox (it may even decrease performance slightly)....i think it looks a whole lot nicer though, gets rid of some more "useless" plastic, and gives me some more room to put more important stuff (i.e. power commander) ;D
there were two different airboxes used. One the filter is square the other the filter is rectangle in shape. The du-9098 is the rectangle one.
Discussion Starter #8
Great, thanks for the info. It just seemed really odd that ducati would go from rectangular to square to rectangular (or the other way around).
Any recommendations on places that offer good pricing on the KN's?
S
aside from your local dealer, chris sells 'em at www.ca-cycleworks.com. not sure if he's got the one you're looking for.
also check out motowheels.com. they sell pipercross filters which are also excellent. may have one to suit your bike.
T
Drop K&N an email I'm sure they'll be able to help you out! ;D
9098 is almost identical to 0900. I've got both and sell them. The new style ones for 03 and 04 Ducatis is different. I think I've got like 2 in stock for those. They're a bit more scarce.
Discussion Starter #12
I just sent you an email for pricing...thanks Chris
Discussion Starter #13
even more strange, look at the 2000 m900 -- all the 900's except for the chromo use one filter, the chromo uses a different model???
I remember seeing a thread someone posted asking what the airbox mod was, and two people posted pics, but one had the folds on the filter horizontal and the other had it vertical, perhaps this is the only difference?
Discussion Starter #14
Chris informed me that the 9098 has a rubberized bar in the middle but in all other aspects is identical tot he 0900 filter.
Thanks all.
1 - 14 of 14 Posts
