Be very careful.. the '02 models are very picky.. I tried that and ended up with a short in the wiring harness... just a word of caution.As a side note removal of the can allows you to start removing several of the frame tie wraps. I'm going to sit down soon and see about getteing rid of all the ties by relocating wiring.
remove everything that isn't necessary makes for a happy duc!
hrm did the wiring rub against something it shouldn't when you moved it? Where did it short out at?Be very careful.. the '02 models are very picky.. I tried that and ended up with a short in the wiring harness... just a word of caution.
