I have a 2002 M750ie Dark. I am in the process of installing Cycle Cat clip ons model DBR-3 and am having a difficult time getting the left side to work properly. If I mount the turn signal/head light/horn control where the pre drilled hole is then I don't have enough room for the grip, it hangs over the bar end by about an inch. I talked to Cycle Cat about this and they asked me to look at the OEM handlebars and see where the pre drilled hole is. oddly enough, its the exact same distance from the end of the bar as the Cycle Cat clip ons. I guess this means that it should work. Am I missing something? In case everyone isn't familiar with the control that I am mounting it is the OEM control box. At almost the exact mid point of the control box on the inside is a nipple that is supposed to fit into the pre drilled hole on the clip on. If this nipple were located all the way to the left rather than in the middle I think the spacing might be closer to working. I know i could break off the nipple inside control but then it moves around on the bar and I don't really want to do that. Or i could drill another hole but that doesn't seem like the right thing to do. I know I must be missing something... Hopefully someone has the answer... Thanks.
