So here's my latest mind **** abortion, I want to add some frame sliders to my bike and instead of using those boring as hell standard sliders I wanted to use 44 mag shift handles (yep, same kind you get right off the custom shelf at pep boys) I have a question though, are there two motor mount bolts or just one long stud?
stik said:
Keep in mind that some sliders e.g. Cycle Cats are designed to break off to protect the frame at certain limit.
Exactly. I wouldn't just put anything there, simply because it may look cool.
If you're not putting an actual engineered frame slider there, you may actually cause more damage to you frame and bike in the event of a slide.
