1 - 15 of 15 Posts
My bike is due for an oil change this weekend. I have heard some people say change the crush washers each time while others say you can go a couple times without changing them. Change? Or not change?
Well, my question was more for curiosity's sake. I know they are cheap and you may as well change them. But, if the dealer didn't have any in stock for instance. Would using them again be a problem provided they are in good shape?
My dealer says they re-use them all the time. Just curious.....
I've used the same washers again several times, changed every other oil change, no problems. Never tried getting more then two changes though.
I keep a bunch of them in my tool box, but I rarely change them. I usually just flip them over & reuse them. If you detect a leak, just snug the bolt a little more. I'm all for spending money on my motorcycles (and have spend a small forture!), but spending money is different than wasting money. Wanna discuss all of the people on this board who waste a lot of money on voodoo oils?? - or throw away tires just because they picked up a nail?? - or...............
The question made me stop and figure out, I've changed my oil 28 times and replaced the washer once. Not sure why as it wasn't leaking . YMMV ;D
If you have a good duc shop, they will give you a crush washer with a filter. No need to replace them every time as long as you are not over tighening the plug bolt.
nah I dont think ya gotta change em, unless its looking pretty ratty.. even then you could get away with sanding it flat. I've had the same one since new (unless dealer did it in the first few services) and mines a 93 model.
whats the worst thats gunna happen, weep a bit of oil?
I changed the oil on my S4R today...didn't replace the crush washer. Working good so far!
I actually bent one putting it back in (doh!) and I pressed it flat, sanded it and it was good to go. I'll replace it next time but it's worked fine for 6000+ miles
If the washer is made of copper, you can heat it on a gas stove until it glows, let it cool down and it should be nice and soft again. We used to do that with Alfas many times when the little thingies were out of stock.
I'm with Norm.
If you really want to change them and don't have ant spares, just go to your local harware store and get some appropriately sized aluminum washers. Crush just fine.
1 - 15 of 15 Posts
