CNC machined from 6061-T6 billet aluminum, CRG levers are adjustable on the fly with a six-position cam system built right into the lever. In other words, a perfect reach is easily obtained. CRG levers are available with grey, gold or black levers, all of which include CRG’s signature red adjuster tab. Easily installed on your bike with no special tools required, these levers add a bit of trick to your ride. All OEM functionality is retained for both clutch safety and brake light actuator switches – no need to fiddle with your bike’s wiring harness!
These are not yet on our website. Available in short or standard length for most models, call TJ at 866-931-6644 ext 817 and be sure to mention you saw this here. You can also send email FORUM at RIDERSDISCOUNT dot COM with the subject line CRG LEVERS and be sure to specify what color you want, and the model/year of the motorcycle you own for accurate availability and fast shipping.
Clutch Lever
All hardware is stainless steel
Brake lever
Cam system is smooth and reliable
Here is the CRG in a gold finish.
Sold individually or as a pair
