CRG adjustable brake and clutch levers allow you to easily position your bike’s controls for optimal reach. The roll-a-click lever mechanism makes adjustment simple to achieve the feel you want for different types of gloves and/or brake/clutch fade. Constructed entirely from CNC-machined 6061-T6 billet aluminum that’s finished by a high-quality anodizing process, these levers look as good as they perform. All hardware is corrosion-resistant stainless steel and the levers come in either standard or short lengths for most motorcycles to suit your style.
These are not yet on our website; call MIKE at 866-931-6644 ext 804 to order. You can also send email to MIKE at RIDERSDISCOUNT dot COM with the subject line CRG LEVERS and be sure to specify if you want brake, clutch or both levers, the color you’d like, standard or short lever length and the model/year of the motorcycle you own for accurate availability and fast shipping.
CRG clutch levers and CRG brake levers come in black, gold or gray anodized colors. Sold individually or as a pair.
There are no rough edges to be found anywhere on CRG levers, the finish machining is excellent.
This simple cam mechanism allows you to adjust the lever reach to suit your needs.
All CRG levers are virtually the same, only the aluminum adaptor you see here differs between the motorcycles they fit on. Because of this, fitment requires no special adaptors or fabrication on the part of the end user to install them on his bike.
