1 - 9 of 9 Posts
Parts i need. please send PMs
2006 monster 620
Front brake master cylinder
front brake lever
front brake resevoir
right hand controls (kill switch and ignition)
lower cowl
New throttle grip and assembly
new stock gauges (or aftermarket, i dont know anything about them)
How bad are the gauges? Is just the case mashed up or is the whole thing done for?
IF the insides can be salvaged, I have a decent casing for you. If not, you'll need a new virgin one from the dealer (about $250)
I have a real nice gauge set from my 02 900S.i.e. that would work on there, $199, did you find all the other parts yet?
are the gauges already coded to a ecu and keys?
If you have the original keys with your ecu in the bike, the gauges should go in and light up/start your bike. They have whenever I tried. The problem I find is the key and ecu always need to be matched. There is a system of turning the ignition on/off and re-setting even an ecu , but you need the red key, black key to switch every 20 seconds. Look on the tech page I will post information as given to me by DUC SHOP.
if this works, there will be a lot of other people you'll be helping [thumbsup]
MM
1 - 9 of 9 Posts
