D
desmodevil
·Guest
I have NO flippin idea how I did it...but it appears I cut it one link too short. frig.
Can I run two master links?
thanks
thanks
Definitely would rather cut it a second time, and run the master links approximately opposite each other.Munch said:Can you run two masters side by side, or are you better cutting the chain, say in the middle, so the masters are evenly spaced out?
+1chris said:Master links have the same strength any place along the chain; put where it will let you sleep the best.
Not me, too embarrassing. If you separate them it is a lot less obvious.bigiain said:+1
If you think the second master link is somehow going to compromise the safety of the chain, then it's already been compromised by the first one...
I'd happily run two master links next to each other if it was me.
big
You should've just cut the stepladder!!!Ash said:im running two masterlinks side by side (thanks chris).
nothing to be embarassed by. you will never beat the reason I had to redo mine:
[laugh]
Cutting the ladder would not help get it on the bike. ;Dpnut said:You should've just cut the stepladder!!!
not the issue at all.Red Baron said:Cutting the ladder would not help get it on the bike. ;D
[laugh] [clap]Ash said:i'm a glutton for embarassment![]()
you've seen that pic before. hell you may have been the first because i had to call you right back and buy a couple more masterlinkschris said:[laugh] [clap]
I'm sure I've done worse! Maybe not with a chain ... but I'm sure I've done things y'all would really laugh at.
;D
Old style frame with the suspension arch would need some disassembly.Ash said:not the issue at all.
you can put an assembled chain on a DSS monster.
you can't on an SSS monster (due to a crossover brace on the swingarm).
I have an m800 (DSS).
Okay, cut the bike then... [thumbsup]Red Baron said:Cutting the ladder would not help get it on the bike. ;D
