i used an 1157, is this correct or will it hurt anything?
G Guest · Discussion Starter • #1 • May 1, 2004 i used an 1157, is this correct or will it hurt anything?
T test-reg · Registered Joined Jun 16, 2003 · 45,105 Posts #2 • May 2, 2004 1157 is the correct bulb.
S ScottRNelson · Banned Joined Aug 16, 2003 · 3,931 Posts #3 • May 2, 2004 The correct bulb is the heavy duty version of the 1157 so that you don't have to change it every few months. I've learned to regularly check the bulb to make sure it's working properly.
