·I went out to setup my suspension the other night, 2001 S4, rear went fine, but the front is strange. What I see on the bike looks little like what is in the manual. I'm sure it's stock, because nearly every bolt on the thing was still factory marked with paint.
Anyway, I grabbed a 22mm socket and gave each leg a few turns, but I'm not seeing what I should be measuring. Should I just crank the front preload all the way, then measure turns?
I've searched and noticed many of you refer to front preload settings by "turns" rather than "mm". Did something change that wasn't updated in the manual?
Thanks!
Thanks!
