1994 Monster M900 with about 40,200 miles on it.
I'd noticed that my clutch had begun to slip a little leaving stoplights about a month ago. I was also having increasingly worsening issues with getting into neutral. There appeared to be a trace of some sort of black, slick residue that was being flung off of the clutch. (It's a dry clutch, so I leave it completely open) I thought it might just be road grime, but I hadn't remembered having the specks on my boot and the junk on my bike before. (Hard to tell...I've been riding in the rain some.) I checked my oil level--looked OK. Bled the clutch--fluid level was fine. The grime looked like carbon and brake fluid mixed together. I have no idea what it is/was.
I pulled the clutch apart to see what was going on. A couple of the plates were pretty worn, but the others appeared decent. There didn't appear to be any of the residue on them that I had expected to find. The push rod was beginning to have the look of being worn I was told. The seals all looked good as far as I could tell. I had just changed out the clutch pack maybe 9 months ago, but I seem to burn through clutches pretty quickly--like in less than 10K miles. I swapped the order of the two worn plates to buy myself a little time while the new pack was on order. It seemed to help a lot with the neutral issue and might have helped with the slipping for a bit.
Since I was ordering a new clutch pack I got a new push rod, seals and needle bearings...the only thing I didn't get was the big seal thingie that goes between the clutch and the motor(?) It was expensive, and since the gooey stuff didn't look like oil, and the shop dude said that that part didn't fail very often, I didn't get it.
So this thing gets all put back together and it rides wonderfully for about 50-60 miles. I take it out for an afternoon jaunt and notice that it slips once or twice. During the course of my 50 mile cruise (some goat-trail stuff) it begins to slip badly on some of the really tight turns where I found myself using the clutch. I find none of the black goop being slung off the clutch, but now there's a visible drip coming out of the bottom of the face of the clutch. I ride it to work over the course of the next week...and it's slipping more and more. The leak appears to be gone, but the slipping is as bad as ever. I called my shop and they said that I should have sealed the bolts holding the basket on--I didn't do that, but I don't remember doing that last time I changed the basket and it didn't leak before (I don't think.)
The clutch comes apart tonight and there's what appears to be clutch fluid (not oil) all over the push rod and inside the housing that it sits in. The plates *look* clean, but every single one of them has been slipping BADLY. I've got no idea where this fluid is from. Slave cylinder? It's an Evo that I had put on a couple of years ago. I had a seal go bad in it once after I did something stupid, but that was probably 18K miles ago and it's been fine. I'm at a loss...where the heck is this leak coming from? Is that the obvious answer to my slipping or is it something unrelated? Stiffer springs are needed maybe? Stack height?
t.i.a.
t.i.a.
