So I got the Barnett aluminum clutch in... kudos to Motowheels for the ultra-quick response. Also upgraded the clutch line to a Gaffer steel braided line. Had to bleed the old fashioned way since I snapped the banjo bolt with the in-line bleeder valve. I already had a Yoyodyne clutch slave installed...
Anyway, what a difference... no more slipping, clutch lever was already improved with the Yoyo, but now the feel is much nicer, i guess due to the steel braided line.
Side note... avoid those cheapo levers seen frequently on ebay. They are certainly not identical to the oem levers. Lesson learned... don't skimp on the levers.
