I'm looking to replace my slave cylinder with an Oberon unit for my '01 M900. Is 29mm the correct slave cylinder size to buy? Any input appreciated... thanks again, Dave
29mm clutch slave cylinder
OK, I'm a little confused here, are you saying that different bore sizes will ALL fit on my '01 M900? What is the bore size of the stock unit? Thanks for replying!, Dave
Yep, as far as the aftermarket ones go, there are a few different companies that make them with different bores and they all fit. Monsterparts.com sells the oberon ones as well as the Evo ones I posted before.
Sorry man, I have no Idea what the stock bore size is....
