·Hey all,
I'm still pretty new to motorcycles -- I bought my used 2000 M750 about 3 months ago. It has 14.4k miles on the odo. Everything has been going pretty well, but lately the clutch has been acting stranger and stranger. Finally today I couldn't even start the bike.
The problem: Any given day I'll start the bike up for the first time, let it idle for a minute and warm up, then put it in first gear and go. Lately the bike has been slightly pulling when i switch to first, even though the clutch lever is all the way pulled in, and the gear should be disengaged. It's strange behavior, but after a few minutes of riding and warming up, it acts normal (no pull when stopped at a stoplight).
So today i go to start the bike for the first time and the bike lurches and stalls out when I shift to first, as if i popped it in gear without the clutch disengaged.
I tried pushing the bike in neutral, getting a running start, then shifting to first, which i was able to do successfully.
Once again, after riding around and shifting gears, eventually the bike started to behave normally. However there were abnormal sounds (seemed abnormal) coming from the bike when I was in motion.
So what do you think? Bad clutch? Should I try to get it fixed, or buy a new one? Aftermarket? I'm new to all this so I'm really curious to get some info.
Thanks in advance.
Stuart
Thanks in advance.
Stuart
