The DBR 13 is meant to go under the stock triple but can also go above if you want a taller position, you might want to ask c cat if you would perhaps need longer lines? Also I would assume that the DBR 13 being a 50mm 'S' clamp with 2.5" rise would also be available with a 1.5" rise? if wanting to go above the triple and finding the 2.5" rise too much...Alex or Alfred should be able to assist you.
Alfred also responded to my email, and gave me the lowdown on their risers, which I'll share for those interested and/or as clueless as me:
"The nomenclature our risers is as follows: F or S refers to Front or Side mounting. The next number, 5, 15, 25, refers to the height of the riser in inches, measured from the top of the clamp ring to the middle of the handlebar, where it mounts to the riser. Thus, an F25 riser is a front mount riser, 2 1/2" high from clamp to bar. Finally, the last number refers
to the fork tube diameter in mm. Thus, an F25-50 is a front mount riser, 2 1/2" high from clamp to bar, with a 50mm clamp ring. All clamp rings are 1" wide.
All risers are priced the same - MSRP $110 ea. That said, any kit can be customized with any particular risers at no additional charge. However, typically, we select those risers, for the standard kits, which provide the greatest range of adjustment and which, based upon the input we get from riders, will meet the greatest number of rider requirements. Often, individuals wish to use a riser other than that which we spec as standard, and buy customized kits, only to find that are, indeed, interference problems... We do go through every imaginable fitment before settling on kit components".
So what I think I want is the DBR13 w/ the S15-50 riser for mounting above the triple clamps, although....
Alex thinks I'll be happier with the new specifically above the triple clamp risers that should be available in 2-3 weeks.
