·Got a question for you about your great ducatitech site -
In your piece on replacing the belts, it says to line up all of the pulley marks, then says once the marks are all lined up, it is at TDC for the ******** cylinder.
What is "*******"??? Horizontal or vertical?
Also, when replacing belts, is it necessary/a good idea to replace the tensioner bearings (or any of the other bearings?). I know on certain cars with belts, replacing the tensioner/idler bearings while doing a belt change is SOP.
Thanks!
Thanks!
