G’day all my 2010 monster 696 choke (throttle adjustment lever) doesn’t seem to be working at all. When moved it doesn’t change the revs at all. is there a way to adjust it or does it need to be replaced cheers
You should pull the tank off and check the cable where it attatches to the throttle body. Its non adjustable so it sounds like the cable either broke or the connection nut came loose.
