1 - 15 of 15 Posts
I'd say just check them whenever the back wheel comes off for something else, like tire changing or replacing sprockets. That's what I do.
If there are no symptoms of failure, like seeing movement between the sprocket/carrier and the wheel hub it can probably wait safely.
Note: If you pull the wheel yourself, make sure you see which way the cone-shaped spacer goes on the left side of the wheel (wide end toward the swing arm). If you put it in the wrong way, either the wheel will drag or the cone will get ground down and the wheel bearings could suffer.
I'm checking my cush drives because of this chart that I'm trying to follow:
http://www.ducatisuite.com/maintcharts.html
But, it seems like a lot of work if you have to pull the rear wheel.
What should I do. Check it or not?
i'm assuming this is your '03 bike? all i can tell you is my cush drives are fine and dandy at 17,000+ miles, 2.5 years old. i doubt they will go bad before you need a rear tire. the Ducati facory repair manual has no inspection interval. certainly, checking them wouln't hurt.
What kind of cush drives does the BST wheel use? Are they similar to the Dymag type?
Norm...I had thought at one time you posted about the wheel reviews in a mag recently.....if it's the same one I saw, I thought there was some comments about their cush drives there, however they were all for GSXR's I think.....
Hi Norm,
The BST wheels include urethane cush drives. They're pretty tough and have been holding up well with the Turbo Hayabusa drag bikes.
Discussion Starter · #13 ·
Thanks Ryan. I needed that. I get obsessive sometimes.
Actually, the break in period (1500 Miles) is over since last weekend. Now I get to ride it harder.
hey moto - are those bushings the same size that Dymag uses? The reason I ask is because I've got raw tubing in 2 different densities that I cut my own from & it would be nice to know if they would also fit the BST.
I have not seen the Dymag cush drives. I can send you some pictures of the BST cush drives if you want.
1 - 15 of 15 Posts
