Have a 1994 M900; Tried unsuccessfully to remove old belts. Removed idler pulleys completely but belts still do not slip over flange on timing pulleys. What is the trick??
Thanks for your help
The earlier motors had a little lip on the outside of the pullies (that Chris referred to). Some people take them off, if not, just use a suitable amount of force, & it will work. The new belts will be fresher rubber & will strech easier. Just cut the old ones off.
