I'm awaiting delivery of an alumnium clutchpack/basket and a billet clutch hub. I see they make a tool to hold the hub so the motor doesn't turn over,but I'm wondering if that might be more for people w/o pneumatic tools? Worse comes to worse I guess I'll make a tool out of the used steel clutch plates, I'm just wondering what I have in store when the parts get here. Only thing I've done clutch-wise on the bike was a billet pressure plate, that was simple enough. I'm thinking this should be about as easy.
Anyone have any FHE to share?
Well sure, you can air gun the nuts off but what about torquing everything back on? That is where you need a good clutch holding tool. When I torqued the clutch hub nut (I forget 150 lbs or thereabouts?) the bike was on a rear stand, I was holding the clutch basket tool and my buddy was working the half inch drive torque wrench with an extension on the end. It's tight.
Good stuff, thanks. I have LT's book I got from dml, I think it's time for a shp manual.
Discussion Starter #5
That's gotta be the best link someones posted a refrence to, exactly what I needed. Thanks.
