have to change the chain on my monster,so was wondering if anyone has a good recommendation on whether or not i should change the sprockets and what to change them to if so???? looking for a lil more get up n go if i could get it from changing them.
Definetely change the sprockets with the chain, go up 2 teeth in the back if your looking for some low end. monsterparts is where i just bought my whole setup, ran a little less than 200 for everything.
+1 on changing the sprocket.
Using old sprocket with new chain will prematurely wear your new chain.
Getting 14 teeth on front sprocket (instead of 15) is a good way to improve too. Your engine will revolve higher ( 1k rpm more at a given speed) so more vibration on highway speed...
