Anyone changed the clutch slave on a 97 750. It has the slave integral to the case cover. This is tonight's project so any advise is welcome. I need to know if the green o-ring goes on the open end of the cylinder or the other. Do I pop out the old with the lever? Just push the new one in place? Any tips are welcome.
hey Kommodo
just use the master cylinder to pump out the piston and then replace the seal. make sure the bore is clean , lube the seal a little(brake fluid is fine) and put it back togeather.
the 97 can be a treat to bleed afterwards so be patient in getting all the air out.
cheers
