I spent Saturday installing a 40-tooth steel rear sprocket in place of my stock 38-toother. I also took the opportunity to raise the rear about an 1 1/4".. both went well.
However, the final step is to adjust the chain tension. This went well until I tried to tighten the axle nuts. My manual says 72Nm... so I went with that. I tightened little by little, alternating sides. Eventually the plate (used to line up with the notches on the swingarm so that you know the wheel is straight) on one side moved with the nut and bent, scratching the swingarm in the process. I backed the nut out a little, and had to hammer the plate back into shape.
I tried the other side, but the plate started to move there as well. It's tight, but not quite 70Nm. Has this happened to anyone before? I probably need to get new plates since I'm not really sure if the wheel is straight now after bending them.
