I need some advice to adjust the chain. How often do you adjust your chain tension?
D Ducster620 · Premium Member Joined May 21, 2003 · 25 Posts Discussion Starter • #1 • Oct 2, 2003 I need some advice to adjust the chain. How often do you adjust your chain tension?
C chris · Premium Member Joined Mar 17, 2003 · 3,677 Posts #2 • Oct 2, 2003 only when i change rear tires. otherwise, sounds like you're too tight.
