·Monsters...
What kind of chain lube should I use?
Cam,If you seriously want to get high milage from your chain and sprockets get a scott oiler.
Cam,
where did you get the Scott Oiller from and how much?
btw, just got myself some Chain Gang sprockets, really need to get them on.
If there is some interest in ScottOilers, I might be able to work up a special price on a group buy from the importer ActionStation.where did you get the Scott Oiller from and how much?
The oil penetrates better on a hot chain, but it doesn't matter if the chain is hot or cold, Maxima Chain Wax will set up within 15 minutes. I was using it to clean some gunk off of my chain, spraying it on, then wiping off whatever would come off. I made the mistake of spraying the whole chain rather than about eight inches at a time, and about ten minutes into the project, I couldn't get any more off with a rag. I had to switch to WD-40 for cleaning.I use Chain Wax... (Maxima I think..) The key is to apply it AFTER you get home from a ride, when the chain is still hot... this way in coats the chain well and is allowed to dry before your next ride..
